Advanced search
It is currently Fri May 24, 2013 2:11 pm
 Page 1 of 1 [ 11 posts ]
Author Message
 Post subject: Adjusting idle speed
PostPosted: Mon Apr 02, 2007 7:19 pm
"Proby"
User avatar
Anyone know how I can raise my idle a couple hundred RPM? Its idling around 500-600 right now and I want it a little higher.
_________________
vision.dynamix Headlight Services
Offline
 Profile
 Post subject:
PostPosted: Mon Apr 02, 2007 8:36 pm
User avatar
I thought it was done automatically by the ECM and not adjustable...
_________________
Ryan - 2000 LGT Limited - Swapped to 5spd
Offline
 Profile
 Post subject:
PostPosted: Mon Apr 02, 2007 9:12 pm
SLi O.G.
User avatar
yeah, it isnt adjustable. Why do you want to change it?
_________________
Lee - Misc Moderator
1998 Subaru Legacy L
Offline
 Profile
 Post subject:
PostPosted: Mon Apr 02, 2007 9:59 pm
"Proby"
User avatar
Damn. I have a humm from the motor that only happens when my car idles low. When I barely rest my foot ont he pedal and it raises the RPMs to around 750ish, the hum goes away.
_________________
Offline
 Profile
 Post subject:
PostPosted: Mon Apr 02, 2007 11:07 pm
Admin
User avatar
It is adjustable.
You have to have a dealership use the Subaru Select Monitor - they can set upper and lower idle limits.
I did this on my 99 Impreza once, it was idling at 600 so I had it raised to 700.
_________________
Offline
 Profile
 Post subject:
PostPosted: Mon Apr 02, 2007 11:15 pm
SLi Resident
you can also set the idle screw so the throttle is always a little [more] open. Subaru says not to do this, but i do it to crank the idle to teach ppl to drive stick. Just mark the factory position with a paint pen.
_________________
1990 subaru legacy- i miss you!
1999 outback 30th deluxe deluxe megafantastic orgasmmobile
subaru has more R&D money than the aftermarket.
Offline
 Profile
 Post subject:
PostPosted: Mon Apr 09, 2007 10:09 pm
SLi O.G.
User avatar
I found this
http://www.northursalia.com/techdocs/pd ... rottle.pdf
so yeah, no touchy screwy
_________________
Offline
 Profile
 Post subject:
PostPosted: Tue Apr 10, 2007 12:26 pm
t3h ch33se
User avatar
You have any sort of intake mod?
_________________
~Mark
2003 Subaru Forester X 5MT 245,xxx miles
1995 LEGACY OUTBACK 5MT (SOLD)
Offline
 Profile
 Post subject:
PostPosted: Wed Apr 11, 2007 11:57 am
"Proby"
User avatar
I have the hum whether my intake is on or off
_________________
Offline
 Profile
 Post subject:
PostPosted: Fri Apr 13, 2007 2:01 pm
SLi Supporter!
User avatar
I use this screw too, no problems. If you change the idle by a lot, you can potentially skew the TPS's reading (it will think your throttle is like 0.5% open when the car is idling). To fix this you have to loosen your TPS and adjust that a little too.
Messing with the idle can be a real pain, though, because the ECU and the IAC does compensate for anything you do with that screw. So you can successfully raise the idle speed to 750, but then you shut the car off and the next time you start it up it will compensate and be back down to 600 again, I found, so you might be fighting a losing fight with the ECU with this whole process.
_________________
- Jey
1995 Legacy Wagon EJ257 turbo
2011 Tribeca Limited EZ36
Offline
 Profile
 Post subject:
PostPosted: Fri Apr 13, 2007 2:46 pm
that's exactly why the throttle plate stop is factory set and should not be changed. the ECU sets target idle and will try to compensate until it can achieve it.
_________________
- Juinior
www.trdsupra.com
1995 Legacy L Wagon - WRX suspension, STi exhaust, lowered, whiteline rear sway, greddy emanage, DIS-2 and a crazy turbo motor that's been sitting on an engine stand for a year waiting to go in
1998 Jaguar XJR
1996 Audi A4 Quattro with a long list of very custom mods
1989 Toyota Supra Turbo - Twin Turbo 7M (the long haul project)
Offline
 Profile
Who is online
Users browsing this forum: No registered users and 0 guests
Search for:
Jump to:
