Advanced search
It is currently Fri Sep 19, 2014 4:51 pm
 Page 1 of 1 [ 7 posts ]
Author Message
 Post subject: Subaru OEM equivalent thread = Permatex & others
PostPosted: Sun Feb 19, 2006 3:55 pm
SLi Resident
User avatar
Hey kiddies. Not wanting to pay ridiculous prices for spec'd sealants & gasket makers from Subaru? Then this is the thread for you. I called Permatex the other day and spoke with one of their techs. I asked him for their equivalents for the following Three Bond products:
1105 - rear diff
1215 - valve timing solenoid (AVCS), valve cover, oil pan
1216 - similar to 1215
1324 - rear diff
Three Bond 1105
Permatex ~29132 (closest they could come...he said very close. there are no resitrictions on this compound, including gasoline. It has a threshold of 400* F)
Three Bond 1215/1216
Permatex 82194 (this has a temp range of -76* to 482* F)
Three Bond 1324
Permatex 81160
Holdite S54
Loctite 542
Now, he also mentioned that they have a product called 'Right Stuff' (#85144) that is a "bead, bolt, torque & go" product. Very little set time, has a body to it (meaning it won't run all over the place) and can be used for rear diffs, oil pans and valve covers. It comes in black and grey; with grey being more specific to import cars. Can withstand 450* F continuous, with intermittent bursts to 500* F. You can use this product without the use of another paper/metal type of gasket. It can also withstand 16 psi. It also has a better overall resistance to synthetic fluids.
Now keep in mind, that these 'equivalent' numbers are a direct correlation to specific sizes of the product. Varying sizes may be available.
Also, if you are looking for a way to better your chances of having no leaks at drain/fill plugs, try something called 'TFE Paste w/ teflon'. It is a non-hardening compound that withstands:
- 3,000 psi on gases ranging from -50* to +400* F
- 10,000 psi on liquids ranging from -50* to +500* F
Can be used with water, steam, natural & LP gas, oils, fuels and dilute acids. It is safe for metals, pvc, cpvc, abs, pp (polypropylene) and nylon. So, my assumption being that this could be used for the following:
oil plugs (drain and galley (for gauge sensors))
tranny plugs (drain and fill)
rear diff plugs (drain and fill)
GGT
search words: 1215 1216 1216b 1324 1105 three bond permatex sealant gasket maker 004403007 0044030042 004403010 holdite loctite valve cover oil pan rear diff differential pumpkin seal oem equivalent safe
_________________
2007 Subaru Legacy 2.5GT spec.B DGM 6MT w/ 4 exhaust tips, 3 LSDs, 225's, stage2!
Wanna see it?
viewtopic.php?p=82481#82481
- traded - 2000 Coma 4x4 AT reg cab - black
- stillborn - 1995 Legacy wagon w/ JDM Ver8 (VF37) & JDM 6MT - 3 LSDs @ +350hp
- no more - 98 BD 2.5GT 5MT BGP -115,000 miles
Offline
 Profile
 Post subject:
PostPosted: Sat Feb 25, 2006 4:39 pm
At my dealership, the sub techs use hondabond when they do headgaskets
(I think on the half moon) I never see em using any sub sealant
Just a thought
_________________
96 white 2.5 dohc gt
90 2.0 4g63T eagle talon tsi awd
93 ford ranger 3.0 auto 4x4
Offline
 Profile
 Post subject:
PostPosted: Thu Oct 16, 2008 12:23 pm
User avatar
Here's some charts from soob service info:
Offline
 Profile
 Post subject: Re: Subaru OEM equivalent thread = Permatex & others
PostPosted: Thu Nov 27, 2008 10:26 pm
Subaru Three bond is one of the worst sealants I've ever used :-(
We use Hondabond on everything that requires sealant here in the shop.
-Dylan @ DS1
Offline
 Profile
PostPosted: Fri Nov 28, 2008 12:09 am
SLi O.G.
User avatar
motorcraft 7.3 diesel sealant works wonders
_________________
98 2.5gt
MA.N/A 413
Offline
 Profile
PostPosted: Thu Dec 09, 2010 10:40 am
User avatar
Hylomar Universal Jointing Compound.
Best shit made!
http://www.hylomarsealant.com/?kc=6NbrC ... bAodOjaw0Q
_________________
Rob
'98 LOBW- Katzkins Leather Interior, JDM Projectors/Sidemarkers, Hawk HPS
'93 Ford F250 7.3 TurboDiesel SCab, 5 Spd, Lotsa mods
'93 Ford F150 4X4 5.0/AOD Winter Beater
'85 Ford F250 Diesel, Toughest Truck on the Planet!
'84 Mazda B2000 Just wont die!
Offline
 Profile
PostPosted: Wed Jul 06, 2011 3:31 pm
User avatar
hmmmm i will argue that and say it's 3M yellow weatherstrip glue. we call it monkeysnot. never will an oil pan leak again. nor come off lolol.
_________________
I hate when rare things are presumed to be desirable. For those who don't understand the difference...
It's rare that I crap my pants. It's usually not that desirable.
My neighbor's told the county that I was operating a subaru dealership/repair shop... snitches...
at my house:
1996 Legacy LSi Sedan (wife's)
1997 Legacy Outback wagon
1996 Impreza Coupe (daily)
1995 Legacy Postal RHD AWD M/T swapped (Roommate's)
1990 Legacy FWD wagon (roommate's girlfriends)
1992 Legacy SS 5MT (friend's project car)
Offline
 Profile
Who is online
Search for:
Jump to:
