Advanced search
It is currently Fri Apr 25, 2014 3:25 am
 Page 1 of 1 [ 8 posts ]
Author Message
 Post subject: Trouble code 420
PostPosted: Sat Sep 04, 2010 5:34 pm
SCAMMER!!!
User avatar
Here is what I got
2002 Legacy L 2.5 motor with 156k
P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
I need to get the car inspected and here in NY, there can be no check engine light on or it wont pass inspection
HOW DO IT FIX THIS PLEASE
the tech at Auto Zone was clueless.
_________________
no signature required!
Offline
 Profile
 Post subject: Re: Trouble code 420
PostPosted: Sat Sep 04, 2010 6:40 pm
SLi Resident
User avatar
Well, correct me if I am wrong, but my gen 2 EJ22 occasionally throws a P0420. I can clear it without issue using a code reader. I believe that the ECU will inhibit the P0420 for something like 120 miles or three driving cycles before allowing the code to show again.... I think...... My P0420 has not come back in a while..... Been spending most of my time on the FZ6.
So......clear it before going to the inspection. Get checked and cleared, and then find the solution..... Then again, you could do the legal thing and check the O2 sensor, check for leaks (this might actually be the problem) and reset the computer..... Hope this helps....
_________________
The three most common expressions in aviation:
"Why is it doing that?"
"Where are we?"
"Oh S...!" *(The last three letters are omitted since when this expression is said, there is little chance to finish it)*
Offline
 Profile
PostPosted: Sat Sep 04, 2010 7:36 pm
Cone Eater
rear oxygen sensor.
_________________
2003 Legacy L "Special" Edition...what's so special about it? CLICK HERE
GO > Show. Every time.
Offline
 Profile
PostPosted: Thu Sep 23, 2010 8:29 pm
SCAMMER!!!
User avatar
so it goes on for about 200 miles, then goes off for 200 miles???
ANYONE
_________________
Offline
 Profile
PostPosted: Thu Sep 23, 2010 8:45 pm
SLi O.G.
User avatar
ANYONE
My Xterra for the longest time would have the o2 sensor come on and I would just clear it and it would come back a some miles later. Chances are if you get an continious o2 failure you are going to have to replace it. Ask me how I know! :roll:
_________________
TJ
99 LGT H6 Limited OBP
viewtopic.php?f=6&t=15702 :twisted:
chuckthefuk wrote:
Offline
 Profile
PostPosted: Fri Sep 24, 2010 8:53 am
User avatar
That's not at all uncommon for that era soob at that mileage. I get that periodically on a 2000 Outback too. It's quite possible the catalysts are marginal at this point - after all that is what the code is monitoring for.
It can be front or rear o2 sensor needing replacement. It can be exhaust leaks, even tiny pinhole leaks. Sometimes it seems to happen on really windy days. Sometimes it happens with fuel from a certain station.
I have seen what some people do is put a spark plug anti-fouler on the rear o2 sensor and supposedly that keeps the code away.
After you clear the codes, make sure you check all the I/M monitors with a scantool before returning for inspection. They have to all say 'ready' or it can't pass. After resetting the codes it can take like a good 3-7 trips for all those to go ready. The evap usually takes the longest.
Offline
 Profile
PostPosted: Thu Sep 30, 2010 12:57 am
t3h ub3r m3mb3r
^^ Yeah there is no way you'll pass emissions by just clearing the code because it will show some of the I/M monitors as not ready.
Subarus are picky about cats. Sometimes you can get by with replacing the O2 sensors, but most of the time, the cats need replaced.
_________________
Kevin B.
06 Subaru Legacy 2.5GT-Brilliant Silver Metallic
98 Subaru Legacy 2.5GT-Black Granite Pearl
<- Turn signals, people! Use them! ->
Offline
 Profile
PostPosted: Thu Sep 30, 2010 8:37 am
Admin
User avatar
Rear o2 sensor...
_________________
Offline
 Profile
Who is online
Search for:
Jump to:
