Advanced search
It is currently Sat Dec 20, 2014 8:51 pm
 Page 1 of 2 [ 37 posts ]  Go to page 1, 2  Next
Author Message
 Post subject: Headlights will not turn off!
PostPosted: Tue Jan 03, 2012 2:36 pm
SLi Resident
User avatar
So last night I went and play in some snow. Got stuck and had to be pulled out by a search and rescue crew. Took damn near 5 hours. When I got home and turned my car off. My headlights stayed on. Regardless if the stalk switch is turned on or off.
The switch works to shut the corner lights off but not the actual headlights. I have to pull the battery so the car doesn't die.
What could this be?
_________________
1996 Subaru Legacy L
Offline
 Profile
 Post subject: Re: Headlights will not turn off!
PostPosted: Tue Jan 03, 2012 3:06 pm
Admin
User avatar
I'd check the stalk switch first, then check your ignition switch.
Does everything else in the car switch off once the key is removed?
_________________
Offline
 Profile
PostPosted: Tue Jan 03, 2012 3:19 pm
SLi Resident
User avatar
Yes everything else turns off. Even the corner lights will turn off when I use the stock. Just not the headlights themselves. Where is the switch in the stalk?
_________________
Offline
 Profile
PostPosted: Tue Jan 03, 2012 3:39 pm
Admin
User avatar
The switch is part of the stalk - when you rotate the tip, it tells the side lights etc to turn on. It's a sliding switch, basically.
If you take your steering column apart, you should be able to trace the wiring to see if that's the issue. Honestly, I'm terrible with electrical so I usually point people to an auto electrician.
_________________
Offline
 Profile
PostPosted: Wed Jan 04, 2012 1:02 am
Moderator
User avatar
There's also a switch on top of the column. That'll keep the lights on even if the stalk switch has them off. I know some people will hit that when they're cleaning or something and not even be aware of it, then not know why the lights won't turn off.
_________________
His: '02 S401 / '02 H6 VDC Sedan / '05 Impreza STi (FOR SALE HERE) / '15 Honda NM4
Hers: '05 Mercedes E500 4matic / '04 Forester XT
Hers: '97 Legacy GT-B Ltd
Offline
 Profile
PostPosted: Wed Jan 04, 2012 1:04 am
Admin
User avatar
That's the P light switch. And it only turns on the park or side lights. Not the headlights.
_________________
Offline
 Profile
PostPosted: Wed Jan 04, 2012 3:01 pm
SLi O.G.
User avatar
Did any damage happen at the time of the incident? Not sure if this is even a possibility, but sometimes losing ground cables does weird weird stuff..
I would check your relays, as relays can also cause these types of weird problems. Its a possibility they just went bad while you were out having fun and has nothing to do with the incident you had. Weird stuff happens in the cold.. :smt021
_________________
http://tinyurl.com/2u8cbx
Offline
 Profile
PostPosted: Wed Jan 04, 2012 3:10 pm
SLi O.G.
User avatar
Our cars headlights are a reverse ground (?) system... so my money is on a loose cable that is grounding out...
_________________
Harry Maneuvers
1999 Legacy Sedan 30th Anniversary Edition EJ251/EJ22 High Compression Frankenmotor http://sl-i.net/FORUM/viewtopic.php?f=6&t=24668
2004 WRX Wagon widebody swap - The Braggin Wagon http://sl-i.net/FORUM/viewtopic.php?f=7&t=24369
2006 Forester XT - Mrs. Fancy http://sl-i.net/FORUM/viewtopic.php?f=7&t=25160
Offline
 Profile
PostPosted: Wed Jan 04, 2012 9:35 pm
SLi Resident
User avatar
Yeah my HID kit froze up or something. Removed them and put normal halogens in and all is well.
_________________
Offline
 Profile
PostPosted: Wed Jan 04, 2012 9:42 pm
SLi O.G.
User avatar
Sounds like the HID system didn't ground out properly or something. Weird.. we'll glad you got it fixed!
_________________
Offline
 Profile
PostPosted: Wed Jan 04, 2012 10:32 pm
SLi Resident
User avatar
Yeah it is awkward. Had no problems for a long time. Doesnt help I dont have a fender liner on my driver side which is where the relay and ballast were sittign.
_________________
Offline
 Profile
PostPosted: Fri Jan 06, 2012 1:46 pm
Admin
User avatar
It would really have helped to know that you had a non-stock lighting system in there from the get go...
_________________
Offline
 Profile
PostPosted: Fri Jan 06, 2012 4:21 pm
SLi O.G.
User avatar
Haha right. And the fact that your fender lining was missing :P
_________________
Offline
 Profile
PostPosted: Fri Jan 06, 2012 9:00 pm
SLi Resident
User avatar
Almost feels like I dont even have headlights now.
_________________
Offline
 Profile
PostPosted: Sat Jan 07, 2012 9:47 am
SLi O.G.
User avatar
Yeah but think of it this way.. people on the road wont hate you anymore! :lol:
Nothing I hate more then when people have HID systems in reflector style housings / housings not made for HID systems.. hurts my eyes!
_________________
Offline
 Profile
PostPosted: Sat Jan 07, 2012 2:23 pm
t3h ub3r m3mb3r
User avatar
I second this and I say having HID's in halogen reflectors it is pure rice... no exceptions
_________________
04 RSTI
98 Legacy Outback
Offline
 Profile
PostPosted: Sat Jan 07, 2012 6:29 pm
SLi Resident
User avatar
Yeah shitty thing. I cannot see the road lines. Or anything at all now. So glad that other people can see (which I was never high beamed) but now....I cannot see. My eyes are far from good.
_________________
Offline
 Profile
PostPosted: Sat Jan 07, 2012 7:26 pm
SLi O.G.
User avatar
Can you just replace the ballasts / bulbs with some new ones? It was probably just something grounding out incorrectly.
_________________
Offline
 Profile
PostPosted: Sun Jan 08, 2012 11:41 am
Admin
User avatar
Projector retrofit. Probably similar cost, better results.
_________________
Offline
 Profile
PostPosted: Sun Jan 08, 2012 12:46 pm
SLi Resident
User avatar
What huffer said, heck you can even see the glare in your avatar
Offline
 Profile
PostPosted: Sun Jan 08, 2012 8:48 pm
SLi Resident
User avatar
I hear its almost pointless to retrofit USDM ones. So I will have to wait for the JDM ones to drop in price again. Pretty spendy especially when I am fixing 2 "reliable" subarus all the time lol.
And to be fair. Maybe its just my eyes. But almost ALL lights glare to me. Even stock halogens on other cars. Even newer projectors. I guess my eyes are just THAT bad.
_________________
Offline
 Profile
PostPosted: Sun Jan 08, 2012 9:59 pm
Admin
User avatar
It's not pointless. Think about it. You get a genuine projector lense with a high low function for less than $200. It's the best upgrade because it's LHD, and it's proven.
_________________
Offline
 Profile
PostPosted: Sun Jan 08, 2012 10:16 pm
SLi Resident
User avatar
Which projectors fit into the USDM lights? And wouldn't I lose the option of the high beam? At least a functional high beam?
Any DIY's or are they THAT simple? Besides I dont have many tools to work with plastic which is my main concern. If I can be into it no more then $300 (cost of projectors and an HID kit) I will be happy. Plus USDM lights are a plenty so I can go to the junkyard and pull some and have no down time.
_________________
Offline
 Profile
PostPosted: Mon Jan 09, 2012 11:33 am
Admin
User avatar
theretrofitsource.com
There's a whole thread on it in the electrical section, which I started and am slowing saving my way towards.
You won't need an HID kit if you have good projectors.
_________________
Offline
 Profile
PostPosted: Mon Jan 09, 2012 12:20 pm
SLi Resident
User avatar
Seems as they come with hids. The price is good too.
_________________
Offline
 Profile
PostPosted: Mon Jan 09, 2012 12:41 pm
Admin
User avatar
You make your own kits up. They don't come with HIDs if you don't want them to. There's a lot of info on that site, and their staff are apparently very helpful so give them a call.
_________________
Offline
 Profile
PostPosted: Mon Jan 09, 2012 3:19 pm
chucktheadmin
User avatar
If you choose the retro-fit method. USDM housings with glass projectors custom fitted, then I really recommend getting a BI-Xenon H.I.D kit. Its a standard HID bulb but its mounted and controlled by a motor. Low beams = nuetral position / High beams = bulb is adjusted up via motor to act as the High Beam.
This is the same concept as the luxury oem brands. Have you ever seen a lexus turn on? The lights move up/down then level them self. Its a form of calibrating the lights.. The units you will buy wont calibrate when they turn on but they will move when Hi/Low switch is activated.
_________________
97' BD9/GT 5MT EJ25D- R.I.P | 96' BG/OB EJ22 - "Off-Road" R.I.P. (450,000+km) | Daily Driver - 00' BH9 OB/5MT
97' BD9/GT 6MT EJ257 - Track
----------------> ALL Factory Service Manuals (FSM) - Direct / Torrent <------------- Download ---------------
----------------------> ALL Subaru Owners Manuals (OM) - Direct <--------------- Download ---------------
---------------------> Part Number Software FAST-II (EPC) - Direct <--------------- Download ---------------
-----------------------------------> Keep SLi AD-FREE !!!! DONATE !!!! <-----------------------------------
Offline
 Profile
PostPosted: Mon Jan 09, 2012 9:19 pm
SLi Resident
User avatar
And if I dont want 2 piece lights? I have the one piece.
Don't like 2 piece lights for many reasons.
And I will get them with the HID kit.
_________________
Offline
 Profile
PostPosted: Tue Jan 10, 2012 11:00 am
Admin
User avatar
Still doable in the one piece headlights.
_________________
Offline
 Profile
PostPosted: Tue Jan 10, 2012 9:38 pm
SLi Resident
User avatar
Heresmymind just told me that I can't use the one piece....."They have to be 100% clear to work".
That I do NOT understand.
_________________
Offline
 Profile
Who is online
Search for:
Jump to:
